Digital guage temp not working? HELP! PLS!!!
I have a 1993 chevy s-10 blazer its got a 4.3l vortec vin code w.
The temperature guage is not working. IT is the digital dash.. Everything else works fine...
I replaced the sending unit on the block for it... whats next... please help!
I don't want to have to mount a manual guage itll look ****ty
so help me find out the solution pls.
Also, When I start it comes on and it goes all the way to the top like the rest of them... then when its running it just wont move up or down.. it stays at 0
so help me find out the solution pls.Also, When I start it comes on and it goes all the way to the top like the rest of them... then when its running it just wont move up or down.. it stays at 0
Is it a one wire or two? If a one, you should be able to connect it to ground and it should peg the temp. gauge-if it does, bad sender. If nothing, cut back-bare the wire back from the plug and see if it 'pegs' the gauge-if that does then..bad plug. Keep us posted. I would guess, either a bad sender or plug. But I guess the temp section of the digital dash could be bad but from my experience-that is rare. Jerry
put a new plug in its okay and sending unit is okay, I guess its the dash... Any clue what it could be... is there a solder point that might be bad or something...?
When I turn it on the entire dash works they all go up to the very top all the guages like they should... and the temp guage lights all work any everything.. its just not getting a reading...
Plug and sending unit is okay...
But what puzzles me about thinking its a bad solder is that... if u dont have the sending unit plugged in the truck will not run... so its definately reading that its there getting a connection
Then you changed the wrong temp sender. There is 2. One for the PCM to get readings from, and one for the gauge. The one you are wanting to change/test is on the passenger side head, not the one on the thermostat housing.
Here is a photo of where it is.
I have located the second sensor... I will go to napa tommorow and get it.. They never mentioned it when I was asking for parts for it... Do you know what the name of this part is? I'll try to explain it to them best I can but sometimes they don't seem very competent there at the shop
Update: Is it the heat guage sender? I looked it up a little bit..
The temperature sensor is for the computer. The temperature sensor is the one for the gauge. As Thomas pointed out, it's in the water jacket on the passenger side of the engine between two of the spark plugs. Hope this all helps...Jerry
David Hineline
Aug 20, 2010 10:07 PM
bertrenolds
Dec 19, 2008 07:45 PM
tyrant46whtcobra
Sep 7, 2008 08:00 PM
DaddyCop03
May 11, 2008 09:07 PM
myronhntr80
Mar 6, 2008 07:58 PM
Now I got a perfectly running 93 chevy s-10 blazer
