distributor cap bolts stripped
Old Jul 2, 2008 | 10:22 PM
matclark's Avatar
matclark is an unknown quantity at this point
Default distributor cap bolts stripped
i have a 94 s-10 blazer 4.3L,,,,,when i replaced the dist. cap, the bolts stripped the threads out of the dist.....i have tried the old bolts and they just keep spinning. any ideas on how to fix this? i would really prefer not to buy/replace the distributor for such a small problem...i have never had this happen to me on any other car i have owned or worked on.....please help !!!
Old Jul 3, 2008 | 06:54 AM
scott96's Avatar
scott96 is an unknown quantity at this point
Default RE: distributor cap bolts stripped
where the bolts go in is it plastic or metal? if plastic you might try a screw thats a little bit bigger, if metal maybe some JB weld might do the trick.
Old Jul 3, 2008 | 08:04 AM
If I were you, I'd try to find a junk-yard distributor to swap in. To fix it, you'll likely have to remove it. I'd just rather find a good core to swap in and be done with it.
Redtortoise38
May 31, 2015 02:32 PM
postal0dude
May 19, 2012 07:30 PM
lcars
14
Dec 10, 2007 03:02 AM
blazerboy30
Nov 20, 2007 09:49 PM
AutomagicLS1
Dec 4, 2006 11:54 PM
