Distributor Question
Old Nov 17, 2012 | 08:56 PM
jaystoy's Avatar
jaystoy is on a distinguished road
Default Distributor Question
Waht might be some of the symptoms of a warn distributor?
Old Nov 17, 2012 | 10:27 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
jumpy timing in base timing mode, bushings in the distributor shaft are binding the shaft, pull cap off and check for how much play is in the rotor when you twist it.
Old Nov 18, 2012 | 03:54 PM
jaystoy's Avatar
Thanks, will do tonight. I notice when it is cold and warming up, it like squeaks from under cap, almost high pitched whistle coming from cap. After few minutes is goes away
Old Nov 18, 2012 | 06:14 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
You could have very irratic idle and miss also when running.
Old Nov 18, 2012 | 06:29 PM
jaystoy's Avatar
idle is good, but I do have a miss. New Plugs, cap, wires, rotor, coil all acdelco. New acdelco fuel pump, new filter. New spider, nut kit and fpr. New egr with screened gasket. Runs great, but after all that time and money, still misses at idle. 166,000 so maybe worn distributor. I have not checked the timing, but the squeak has me stumped.
SevereDevil
Jun 2, 2009 08:40 PM
marksoftball
Jan 12, 2009 10:43 PM
blkblazerLT
May 7, 2008 08:20 PM
95Blazer4x4
Feb 1, 2008 08:19 PM
88YJGirlly
Engine & Internal
Jul 7, 2006 09:59 AM
