Does anyone know where i can find an EPROM
blazer returned a code 43 on the scanner tool. also returned a code 32 so my mechanic said the ECM its self is functioning but the eeprom is toast. having hell trying to locate one. called all the local junk yards and local GM dealerships. even called GM itself... its looking like i might be sol. i dont want to kill my truck but its not working all that great. PLEASE HELP if you can!
-Wes-
-Wes-
RE: Does anyone know where i can find an EPROM
hmm does anyone know how i can test to see if its the eprom or the ecm? ive talked with a few people and they say the odds of if being the eprom are slim to none.
EPROM == ECM unless it is a problem with a voltage regulator or other circuitry. You could pull the EPROM from any S-series vehicle with the same engine/transmission. Or just pull the whole ECM and see if that fixes your problem.
a mechanic told me it also has to be the same gear ratio... is this true? for the eprom that is.
Yes, you will want to look at the RPO code list and match up the gear ratios.
where can i find an rpo code list?
On the inside of the glove box door.
kms
03-10-2012 07:50 AM
juicy_jay_510
11-28-2008 01:28 AM
zombiewoof
02-24-2008 11:18 PM
hillbillyinOhio
12-13-2006 03:40 AM
