Don't Know what to do with this problem
Old Aug 14, 2009 | 12:59 PM
Originally Posted by AJBert
Just a heads up, the circuit boards are known for failing due to cracks developing in the soldered connections causing all kinds of havoc. A new circuit board only runs about $20 and is very easy to replace.
Or you could resolder the connections as shown in the thread below:
Fix for cold solders in the Wiper Motor
Old Aug 14, 2009 | 06:10 PM
tony991's Avatar
tony991 is on a distinguished road
ok... i pulled the wiper motor off today.. and on mine, you can't take the cover off.. its rivited on.. is there anything else i can do.. cause i really dont want to have to buy a new motor if i don't have to...
Old Aug 14, 2009 | 07:54 PM
AJBert's Avatar
Drill out the rivets and pull the cover off. Use bolts and nuts to reattatch.
Old Aug 16, 2009 | 07:50 AM
tony991's Avatar
ok ill give that try..
Old Aug 17, 2009 | 11:45 AM
tony991's Avatar
i drilled out the rivits on the wiper moter... and there is no circuit board at all...
Old Aug 17, 2009 | 12:06 PM
mr.vls's Avatar
If you do not have the delay system I am not sure if there is a circuit board or not. The fault isolation I listed in a previous post had two different approaches. One with delay and one without.
Old Aug 17, 2009 | 12:11 PM
tony991's Avatar
so.. what do you think i should try now??
Old Aug 17, 2009 | 12:59 PM
tony991's Avatar
could the circuit board be located somewhere else?
Old Aug 17, 2009 | 01:35 PM
mr.vls's Avatar
base wiper system the following applies: With Ignition Switch On, Wiper Switch in Off position, remove connector from wiper terminal, connect jumper from terminal No. 2 and No. 3 and 12 volt source to terminal 4. if wiper parks replace column switch, If Wiper still runs repair wiper motor (Check Park Switch Actuator and Brush Holder Assy)
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
BlazerLT2001
Jun 23, 2010 09:51 PM
havrelm1
Jul 24, 2008 09:26 PM
cvcmama22
Apr 7, 2008 06:41 AM
grubdub761
Oct 18, 2007 02:48 PM
