driver' door accessory relay
Old Jan 21, 2010 | 12:28 PM
greenbean's Avatar
greenbean is an unknown quantity at this point
Default driver' door accessory relay
This site is awesome!!!!
Trying to locate the driver's door accessory relay
the part number is 19884, autozone
oem# 12065122
Does anyone know where it is located on the truck
I have a 94 4.3 4x4 vortec tahoe 4 door
With this site's help I replaced the power window motor (driver's side)
Saved up for the power door actuator
Replaced the door actuator and the driver's door lock still does not work
The plug into the actuator is receiving power when I use the remote with a test light
I checked over the install and still no luck
The three other doors work
Also the power mirror does not work on the driver's side as well as the power lock button
The power lock button is not receiving power at all
All the passenger side accessories work
thank you for your time
Old Jan 21, 2010 | 06:41 PM
Above the gas pedal.
Old Jan 22, 2010 | 11:16 AM
greenbean's Avatar
thank you for the location
I will get to work on it tomorrow am
darknight666
Nov 4, 2014 07:10 PM
PinkCamo
Apr 1, 2011 07:08 AM
bestes
May 31, 2008 03:16 PM
TheRealFitz
Nov 25, 2006 07:05 AM
