Accessory/Ignition wiring?
Old Nov 25, 2006 | 03:55 AM
TheRealFitz's Avatar
TheRealFitz is an unknown quantity at this point
Default Accessory/Ignition wiring?
Hey guys, I'm new to your forum. Yes, I used Search first, haha.
My cousin owns a 2000 Blazer LS and we're adding a simple low-draw 12V accessory unit. I want to tap into the ignition controlled accessory harness to avoid the mistake of the unit being left on after key-off. Is there such a harness on Blazers, and if so, where can I find it to tap into it?
Photos, wiring colors, etc. are massively appreciated.
Thanks, guys!
-Fitzy
Old Nov 25, 2006 | 07:05 AM
hillbillyinOhio's Avatar
Default RE: Accessory/Ignition wiring?
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 White Ignition Switch Harness
Ignition 3 Brown Ignition Switch Harness
Accessory Orange Ignition Switch Harness (Heat/AC)
greenbean
Jan 22, 2010 11:16 AM
global_dev
Nov 24, 2009 06:42 AM
bigt61
May 29, 2007 01:56 PM
zsipe41
Feb 6, 2007 01:03 AM
