Drives side widow came off regulator
Ok. So, It came off, so that means I will need the clips, but I have a regulator question (it is electric).
The arm works along with the motor, so I have the glass up (its been raining and its propped up. So, How do I put it together? Does the arm slide into the metal bit at the bottom? Does anyone have any links to pictures, how would I go about putting it back together?
Thanks
Thanks
i dont have pics BUT ... i done this before on mine .
the arm from the regulator goes in the track attached to the bottom of the window .
i have had to replace the motor on a few of my windows so i have just took the pannel off , drilled out the rivets and replaced the motor . just a side note , if you ever have to do this BE CAREFUL !!!! THE REGULATOR IS SPRING LOADED AND LIKES TO HURT YOUR FINGERS !! check your roller on the arm to ensure its not wore out
(mine was ,and had to get a new regulator)
a follow up
Is there a way to take the actually metal door off, i got the handle and the foam off. but i didnt see a way to do that. So i can get to the regulator and motor better.
Thanks
Thanks
sorry, been really busy ,
the regulator , motor assembly is riveted onto the door !
in order to remove it, you must drill out the rivets !
then you can slide the arm out of the track integrated into the bottom of the window
you will want some 1/4 " bolts to replace the rivets (stubby) and i recomend some nylock nuts , so they dont back out on you .
once you remove the rivets be ready to catch the window through the bottom and grab the regulator/motor ***. with the other hand
oh ya the track is attached to the bottom of the glass in a semi permanent fashion , so taking it off , is not recomended !!! (unless you know what your doing )
trailblazin88
04-18-2011 08:15 PM
Wexinlo
04-06-2011 11:35 PM
