egr valve clean
egr valve clean
what exactly are the symptoms of a 'dirty' egr valve? i 'cleaned mine out today' with throttle body cleaner. i've heard mention of soaking them over night. is the screen on the gasket overly beneficial?
any feedback would be sweet.
ps: it was removed with 10mm socket. used extension on driver side bolt. only have to detach air hose and corresponding wires.
A stuck open egr is basically a huge vacuum leak. Horrible idle, poor acceleration, but drive-able at speed. The screened gasket is a must!!!! Chunks of carbon from the intake is what sticks in them and holds the little plunger open. If you go back with a regular gasket, you will more than likely have the same problem again very soon.
I'm not sure you would be able to hear it, but it would be very noticeable from the way the engine would be running, in my experience.
IndianaBlazerGirl
09-06-2011 06:22 PM
