Electronic 4X4 Button
Old Mar 26, 2008 | 01:39 PM
Vette Guy's Avatar
Vette Guy is an unknown quantity at this point
Default Electronic 4X4 Button
Hi I'm new here. I just got a 1993 S-10 blazer, 4.3L. There is no book with the truck and I was wondering if someone could help me get it back into 2 wheel drive. Its now in 4LO and there is just a spring loaded rocker switch on the dash that says 4HI or 4LO but nothing on the switch says 2 wheel drive. Thanks for any help. I am sure I will be back with more questions.
Old Mar 26, 2008 | 09:09 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Default RE: Electronic 4X4 Button
first you must put it back into 4hi do this by pushing the 4hi button (it should glow green if it engaged) next to put it back into 2 wheel drive simple push the 4hi button agian the green light should go off and you should hear a clicking as it works
second if the light flashes at you that means it hasnt engaged and will abourt trying to engage after 30 sec so make sure your not in 2wheel drive now and think you are in 4LO. i had that problem and ended up getting stuck in a snow drift
Old Mar 27, 2008 | 03:58 AM
drperry's Avatar
You're probably gonna want to be in neutral switching from 4LO to anything else...
Old Mar 27, 2008 | 05:21 PM
Thor_449's Avatar
oops forgot about that but you would have to be in neutral to get to 4LO
762mm
17
Nov 21, 2024 11:36 AM
Flyfishen
Jun 18, 2019 11:22 AM
RCarp48
Jan 31, 2009 01:48 AM
LittleT
Oct 4, 2007 02:35 PM
backusm3
Jan 26, 2007 02:34 AM
