4x4 electronic transfer issue
Old Jan 25, 2007 | 12:31 PM
backusm3's Avatar
backusm3 is an unknown quantity at this point
Default 4x4 electronic transfer issue
I am having trouble getting my '97 4x4 to get into 4-wheel. ive read alot of people having the problem where the light flashes for 4 wheel then goes back into 2. however with mine the controller is just dead. Im assuming there is just some corrostion somewhere that needs to be found. there is no engine light on so i doubt it is putting out any code. Also, my dash lights are on when my lights are off, and off when the lights are on. This problem happened at the same time so i assume the two connected somewhere. Any leads into what the problem may be?
Sincerely,
Michigan driver stuck in the snow.
Old Jan 25, 2007 | 12:48 PM
hillbillyinOhio's Avatar
Default RE: 4x4 electronic transfer issue
did you check the tcase fuse??? i would check that first, actually,go through youfuse panel and check every fuse, meaning, pull it out and verify that the fuse is not blown. then let us know what you found
Old Jan 25, 2007 | 10:49 PM
backusm3's Avatar
I was hoping I would be able to post again before anyone replied. I dopened up the fuse panel and sure enough there was the problem. I guess im so used to problems never being that easy. Call me a 'glass is half empty guy'. As always i sincerely appreciate the help and quick response.!!!b
Old Jan 25, 2007 | 10:57 PM
Man, Im on fire!!! glad you got it worked out
Old Jan 26, 2007 | 02:34 AM
backusm3's Avatar
Im really eating my foot on this one. The fuse pops everytime i turn on my headlights. Pinched ground maybe in the headlamps switch or could it be anywhere on that circuit?
-'you keep that skoal baby.'
Talyn
Apr 5, 2011 02:52 PM
RCarp48
Jan 31, 2009 01:48 AM
Vette Guy
Mar 27, 2008 05:21 PM
LittleT
Oct 4, 2007 02:35 PM
Ptownblazer
Jun 18, 2007 11:34 PM
