Engine "Dieseling" - continutes to run after being cut off
Old Aug 2, 2007 | 09:36 PM
BradensCreed's Avatar
BradensCreed is an unknown quantity at this point
Default Engine "Dieseling" - continutes to run after being cut off
what are the most common reasons my 84 2.8 v6 carb motor would do this? let it warm up and idle for a while, cut it off and it chugs and sputters till it dies, usually about 5 seconds. hitting the gas makes it almost rev then die. has been sitting for six months. got it from a guy for a good price... if i can diagnose this.
Old Aug 14, 2007 | 08:58 PM
joseph296's Avatar
joseph296 is an unknown quantity at this point
Default RE: Engine "Dieseling" - continutes to run after being cut off
i jsut solved this problem in my 94 v6 it was flooding due to a bad fuel preasure regulator
Old Aug 15, 2007 | 06:46 PM
drperry's Avatar
Totally unrelated to his engine... There is no pressure regulator...
The carb could need rebuilding, or if your lucky just some tuning.
Old Aug 15, 2007 | 07:44 PM
I made a pretty thorough post on engine run-on a while back... Here ya go --> CLICK HERE
Old Aug 24, 2007 | 11:24 PM
not bad. got a can of sea foam and checking the timing as soon as i can. def needs a good tune up so thats going to happen regardless. quick question... what are the benifits of using sea foam in your oil as well as in the gas?
Old Aug 25, 2007 | 03:22 PM
Seafoam in the oil is to clean out any deposits in your engine oil system. It should only be run for 250 miles MAX. In the gas it acts as a fuel injector cleaner, but there are better alternatives for fuel injector cleaners.
dbarrowjr
Jan 14, 2014 05:53 AM
fireman846
Jan 14, 2011 09:31 AM
sedatedbylife
Engine & Internal
Feb 27, 2010 10:54 AM
2000_BlzrLT
Mar 23, 2008 07:27 PM
rewj
Dec 19, 2007 07:43 AM
