Engine Degrease
Old Nov 7, 2005 | 03:24 PM
89Blazze's Avatar
89Blazze is an unknown quantity at this point
Default Engine Degrease
Hello All..Question for all....I want to degrease my Engine 89 Blazer 4.3....Is there any parts that i should cover, wrap or remove in order to AVoid any water related issues...Any and all suggestion will be greatly appreciated...
Old Nov 7, 2005 | 04:05 PM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Default RE: Engine Degrease
Mostly just the distributor and intake. Don't want water in either of those. Pick up a can of STP Wire Dryer, it rocks.
Old Nov 7, 2005 | 05:25 PM
You will also want to throw a plastic bag over the alternator as well just as a precaution. Really, everything under the hood can get wet, but you wouldn't want to put a direct flow of water onto the alternator or those things mentioned above.
**EDIT - Oh and Simple Green mixed 10:1 (10 parts water to 1 part simple green) workes wonders on a greasy engine. Plus, it isn't all that expensive and environmentally friendly (or more so than other degreasers)...
Old Nov 7, 2005 | 09:46 PM
drkmelvin's Avatar
drkmelvin is an unknown quantity at this point
I find that spraying wd40 on all wiring harness plugs helps out a lot also
Old Nov 9, 2005 | 06:33 PM
Hanr3's Avatar
I wash mine at the car wash. I use the low pressure setting unless it is really muddy. Then I will hit it with the high pressure hose. I leave the engine running and try to avoid the distriburator cap and intake. To degrease, I use the tire cleaner.
N.alaska_blazer
Feb 23, 2009 01:31 PM
Tony H
Dec 14, 2008 02:04 AM
johinut
Oct 24, 2008 04:06 PM
loppy crimp
Sep 11, 2008 08:31 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
