engine help
Old Mar 26, 2007 | 03:55 PM
iceman1987's Avatar
iceman1987 is an unknown quantity at this point
Default engine help
i have recieved a 1985 2.8 s-10 engine, and i am going to be doing a overhaul/rebuild of the engine and what i would like to do is put fuel rials(fuel injection) on the engine....is this possible? and if so what will i have to do?
Old Mar 26, 2007 | 04:03 PM
Default RE: engine help
So you'd like to go MPI and not TBI correct? It's going to be fun, I can assure you that. Your 2.8L now is TBI is it not? You probably can weld injector bungs onto your current intake. You would then probably have to have someone fab up some fuel rails.
Next problem you'll run into is a higher output fuel pump. Your TBI engine doesn't require the pressures that a MPI system requires. And I cannot remember if the old TBI 2.8L was a returnless fuel system or not...
Old Mar 26, 2007 | 04:19 PM
iceman1987's Avatar
yeah, your right so far...but i thought someone is selling the rails to convert from carb to fuel injection
Old Mar 26, 2007 | 04:46 PM
It is quite possible... I had a feedback carb'd 2.8L in an '85 S10 pickup, but beyond working on that dog, I don't have a bunch of experience with the 2.8L except in passenger vehicles that already had MPI.
Old Mar 26, 2007 | 05:08 PM
iceman1987's Avatar
there was 1 posting before that i will have to find where he was doing the same thing and he said that all you really have to do is install a fuel filter in the gas tank
Old Mar 26, 2007 | 06:09 PM
20Blazer00's Avatar
ORIGINAL: iceman1987
I am sure he was just talking about the fuel pump. If you are going to switch to MPI fuel injection I would research the possible intakes from the GM 2.8L family and if you can just bolt up the top end (intake, heads etc...) or find an MPI engine to start with. Because you are probably going to need a computer to control the injectors and other sensors, along with the wiring needed to make the swap...
Your current TBI system uses batch fired injectors in a carb style body, the MPI system would fire the injectors as needed and would require a different computer.
Old Mar 26, 2007 | 08:18 PM
Correct me if I'm wrong, but aren't most of the MPI intakes for the 2.8L are on passenger vehicles with DIS?
Old Mar 26, 2007 | 08:42 PM
iceman1987's Avatar
the air intake is on the driver side...is that what you are talkin bout...is not than what is DIS....?
Old Mar 26, 2007 | 11:36 PM
DIS == Distributorless Ignition System
And yes, most of the transverse mount engines (FWD) do have the TB positioned at the back of the engine.
Old Mar 27, 2007 | 09:04 AM
drperry's Avatar
Fuel injection didn't come to the S-Series until 1986...
'85 is pure carb baby!
an MPFI setup is going to be a pretty nasty job, because you'll have to drill injector holes for each cylinder. You'll need heads at the very least from an MPFI setup, and an electric fuel pump...
It's not worth the hassle trying to MPFI the carbed 2.8.
Steal an MPFI 2.8 from an F-Body, and you will be MUCH better off...
It's still a direct drop in... And you'll only need the fuel pump, and possibly gas tank...
N.alaska_blazer
Feb 23, 2009 01:31 PM
Tony H
Dec 14, 2008 02:04 AM
johinut
Oct 24, 2008 04:06 PM
loppy crimp
Sep 11, 2008 08:31 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
