Engine lost its power
Old Jan 9, 2011 | 03:53 AM
jannes_z-28's Avatar
jannes_z-28 is on a distinguished road
Default Engine lost its power
OK, now when I found the ODBI connector I've got some codes to help solve my problem.
I got codes 33 & 45
33 = Map sensor signal out of range, High
45 = O2 sensor rich exhaust.
Before I started it I only got Code 45, it was cold and ran rough and after that run Code 33 showed up.
When its warm its idle normally but when cold its rough. The EGR is moving so it maybe is OK.
The exhaust smells of fuel, looking down the TBI it looks like a lot of fuel, I can see drops on the throttle blades.
When running it is out of power, pushing the gas pedal results in bluddering and powerless.
I suspect some kind of fuelproblem but would appreciate some hints on where to start looking.
Thanks
Jan
Old Jan 9, 2011 | 09:14 AM
I would take a look at the MAP sensor first. This sensor is used to determine engine load for fuel requirements (along with a few other sensors). An incorrect reading from this sensor could cause the symptoms you are experiencing. I have posted the MAP sensor values for various elevations in other threads. A search for "MAP+elevation" with an author of "swartlkk" should turn up the relevant information.
Old Jan 13, 2011 | 04:02 AM
I have changed the MAP Sensor now but it didn't do any difference.
When looking for parts I found that Standard # AS165 should be the one for my S10 Blazer, it would fit 84-94. This one was unfortunately rest ordered and they suggested Standard #AS5 for S10Blazer 86-90, mine is a '92.
I got the AS5 but my problems are the same.
I suspect that the MAP sensor I got isn't the proper one for my car.
Would these two make that much of a difference?
Jan
Old Jan 13, 2011 | 12:13 PM
Shouldn't make that much of a difference.
Old Jan 14, 2011 | 03:24 AM
I am struggling on with my car.
I got an used MAP sensor from another S10 Blazer and it didn't make things any better. So I have to start looking for other reasons for my problems.
Must be some fuel problems. Now it doesn't even try to start, just dead with an occasional sputter.
I will check the fuelfilter, I did change that a year ago, but I guess they can clog up anyway.
Jan
Old Jan 14, 2011 | 11:02 PM
Wink's Avatar
Wink is on a distinguished road
Ok, it seems to me you probably should brake out the good 'ol multimeter and a good set of eyes. Check your connectors. See if any of the wires are broken or if the connectors are corroded. Bad connectors seem to happen a lot in humid climates.
With the multimeter, make sure you're getting 5v DC on the power wire. Then check the ground wire to a good chassis ground to make sure that wire isn't bad to the ecu. As for the signal wire, just unplug the ecu and test for continuity. It sounds like you have a problem with the harness or connector.
Old Jan 16, 2011 | 08:46 AM
Default Engine lost its power, now it is dead
OK, I have done a few things but I am going downhill on this.
I have changed the fuel pressure regulator.
I have changed the MAP-sensor, it reads 4.8V when ignition is on and engine not running. It reads between 4.0 and 4.3 when cranking on startmotor.
I have checked the fuel filter and the injectors spray fuel when cranking.
It has spark (at least on cyl 1)
I have cleaned the distributor cap from some oxide.
I have no error codes anymore ( I had for the MAP before it was changed)
But it won't start, it is dead, it can sputter occassionly but it is more or less dead.
I can't see any loose hoses or connections. There is no mechanical noise.
What should I do???
Jan
Old Feb 9, 2011 | 05:35 AM
I have struggled with this problem and I am still nothing near a conclusion.
So far I have changed almost everything.
Fuel pump
Fuel pressure regulator
MAP
Coil
Ignition module
Rotor
Cap
Sparkplugs
Temp sensor
At least I now get it started but it will not run. First time it started it ran almost ok on idle but as soon as I touched the gas pedal it dies.
Then it only starts with wide open throttle and will only run very roughly with WOT and then it dies if I lift the throttle.
It smells a lot of gas and is apparently running very rich.
What can be left to do, I am out of ideas.....
Thanks
Jan
Old Feb 9, 2011 | 06:02 AM
cochran07's Avatar
cochran07 is an unknown quantity at this point
Have you checked your fuel pressure?
Old Feb 9, 2011 | 06:39 AM
No, I haven't but as you see I have a new pump and regulator.
Jan
