engine stalls when on the gas after long idle
Old Jan 20, 2009 | 01:28 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Default RE: engine stalls when on the gas after long idle
That's TBI. The 8th digit of your VIN should be Z.
Do you have an SES light on? Any codes?
No, discoloration will mean nothing on an oxygen sensor. The procedure is around here somewhere.
Old Apr 7, 2009 | 11:22 AM
gnpower's Avatar
gnpower is an unknown quantity at this point
Default update
I've replaced cap, rotor, air filter, fuel filter and plugs (no wires). Ran injector cleaner and combustion chamber cleaner. Very sporadic/random issue. Happens at anytime. It will drive fine one second and then at a stop light it sounds like it gets no gas when you step on th pedal. You have to feather the gas ever so slightly to get it to go. If you press on the gas normally, it chokes and may die if I keep on pressing the gas. When it gets to that state, then it idles at 2k rpms. There are no codes. I did replace the ecm very recently because I totally died on me. I'm thinking maybe a stretched timing chain? It does have just over 200k miles on it.
Old Apr 7, 2009 | 11:23 AM
gnpower's Avatar
Originally Posted by swartlkk
Are there holes in the exhaust before the oxygen sensor?
No holes
Old Apr 7, 2009 | 02:43 PM
A stretched timing chain should not cause a spuratic issue.
Old Apr 15, 2009 | 08:37 PM
highheelsnhandguns's Avatar
highheelsnhandguns is on a distinguished road
Hi, 1983 s10, same problem, did you come up with anything? Had this truck 20 years and never this trouble before. @#$%^^^^help!
Old Apr 20, 2009 | 12:48 AM
bumsinthehouse's Avatar
bumsinthehouse is on a distinguished road
a good way to check the timing chain slop is to get number one cylinder on the top of the compression stroke on top dead center and pull of the distributor cap and see if the rotor is pointing at cylinder 1 plug wire but other than that my pcv valve on my 89 4.3 tbi actually made my truck hard to start and lose power from time to time.
kpriddy91
Feb 28, 2012 01:04 PM
cide
May 4, 2009 02:23 PM
danrnelson7@hotmail.
Feb 16, 2009 08:32 PM
Roma
Jun 18, 2007 03:04 AM
see119
Aug 30, 2005 02:00 PM
