Extended crank when starting cold....?
Old Mar 5, 2011 | 01:17 PM
ely0569's Avatar
ely0569 is on a distinguished road
Default Extended crank when starting cold....?
I have a 94 S10 Blazer 4.3l 2dr 4X4 and when I start the thing cold it takes me having to tap the gas a little before it starts. It runs great after starting and when it has been ran and is warm, it starts right up. I just replaced the EGR and cleaned the throttle body and and upper intake with Seafoam DeepCreep (which works great). I haven't changed the cap, rotor, wires, and plugs yet but I do plan on it. What could be the issue?
Old Mar 5, 2011 | 02:59 PM
ffox's Avatar
ffox is on a distinguished road
The plugs and other ignition parts can cause that, so can low fuel pressure caused by a weak fuel pump or a clogged filter.
Old Mar 5, 2011 | 03:33 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
next time you start cold, let it sit in run but dont crank for about 5 seconds to see if once it gains some pressure in the fuel system up it'll start easier.
Old Mar 5, 2011 | 04:47 PM
ely0569's Avatar
I do let the fuel pump run before I crank everytime I start it. Pump sounds strong (not saying that means it is) but I do not have a fuel pressure gauge to check it. I am calling a mechanic friend of mine tonight to borrow his...
Old Mar 7, 2011 | 06:13 PM
ely0569's Avatar
When itI does start it smells of fuel, almost like it is flooded. It runs fine though......I guess I'll just wait and see
dawnorrhea
Nov 12, 2009 04:13 AM
rriddle3
Mar 11, 2009 07:35 PM
JediKnight2
Feb 13, 2008 07:22 AM
killerelfboy
Jan 11, 2008 12:44 PM
Verzwyvelt
Jul 14, 2007 12:07 AM
