fire from exhaust/smells horrible/wont idle
Old Nov 2, 2008 | 03:25 PM
BradensCreed's Avatar
BradensCreed is an unknown quantity at this point
Default fire from exhaust/smells horrible/wont idle
just what it says. 93 with a 4.3 vortec. was coming from a red light and gave it full throttle. hesitated slightly and then accelerated. when i came to the next light 1 mile down the road, it felt as if it was going to stall, shaking the whole vehicle violently. got it to the house as quick as i could. got out of the truck and left it running. the smell was horrbile. i know i know, but its not rotten eggs. in fact it doesnt even smell like gas. i cant descibe it. maybe burnt popcorn? either way i look under the truck and (i have a hole in my muffler) blue flames are just pouring from the hole. it burned 1/4 tank of gas in 42 miles. all im asking is, could it be the fuel pressure regulator? throttle position sensor? just gimme an idea so i have somewhere to start. thank you in advance.
Old Nov 2, 2008 | 03:58 PM
Default RE: fire from exhaust/smells horrible/wont idle
Fuel leak under the plenum. My first guess would be the FPR.
Old Nov 2, 2008 | 04:08 PM
that was my first guess as well. judging from what I've read these are prone to failure? I've never smelled anything like this. its almost the rotten egg smell like a clogged cat but so much more strong, and not quite eggy if you can follow. just rancid and it lingers for HOURS. cat is certainly not clogged though with 8 inch blue flames just pouring from the exhaust.
Old Nov 3, 2008 | 05:24 PM
can anyone give me a quick write up on how to remove the fpr? im getting one tonight and ive never messed with anything on this truck before. i read the haynes manual but i dont even know what this looks like. im getting a reman. one from O'Reillys for under $50. and the guy said it even comes with the tool?! im lost.
Old Nov 3, 2008 | 08:36 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
The tool is a torx security bit (has a hole in the center for the corresponding pin on the screw) - you will need a bit driver to use it.
Here is a write-up with photos:
http://www.automotiveforums.com/vbul...d.php?t=503238
The photos will show as question marks - if you right-click on it and choose open in new tab (or window), you will see them.
And a thorough write-up without pics (though you don't need #16 on if you are just doing the regulator):
http://www.automotiveforums.com/vbul...d.php?t=462726
You will need a Torx T-30 bit for the Vortec cover and a 10mm deep socket for the nuts/studs around the upper plenum.
tall_ish
Nov 20, 2010 09:05 PM
corhey88
Jan 21, 2010 06:28 PM
corvetteman
18
Jan 20, 2010 04:37 PM
pipslittlemomma
Feb 28, 2009 10:10 PM
juan8w1
Nov 8, 2008 04:57 PM
