first gen 4.3 temp gauge problem
Old 02-11-2018, 08:18 AM
error_401 is on a distinguished road
The rear side panels are screwed in.
If I properly remember starting at the back, you also need to pull the hatch rubber-gasket.
May also need to remove:
Door sill cover in order to remove the vertical cover along the rear hatch post (L/R)
Then the vertical cover on the rearmost pillar in order not to break the plastic. (along window vertical)
I think there were a few small round caps which had to be pulled using a small screwdriver.
You have to remove the covers and look inside.
Put the rear seat down to access two or three along the bottom.
Under the carpet as well if i properly remember.
The book says it is a two-piece molding over the wheel wells, split about where the backrest of the rear seats is. I think mine was a single piece which was the reason I had to unscrew to the bottom of the rear passenger compartment to remove the side trim.
If you want to remove the whole side covers:
May need to remove the seatbelt bolt (large Torx T45 or T50) to completely remove the panel.
In any case - It is screwed in, so pull gently to locate attachment points, but it cannot be pulled away!
As for the temp sender - I'll head to the garage tonight, been abroad for a week.
Old 02-11-2018, 08:25 AM
vincent1972's Avatar
vincent1972 is on a distinguished road
thx already for this usefull information
Old 03-10-2018, 04:39 AM
Still due with an answer to the temp sender unit.
Couldn't find a second sensor. Book also says only one.
Had the red overheat show 21 years ago. So memory may has let me down on the two sensors.
So changing the one sensor should get a valid temp signal.
But then the digital clusters can fail in funny ways.
Old 03-16-2018, 05:44 AM
mr.vls's Avatar
mr.vls will become famous soon enough
Right cylinder head should have the temp sensor for gauge. The one by the water inlet is for the ECU. There are 2 different sensors for the dash depending on if your dash has a gauge or a idiot light. The sensor in the head is a one wire sensor and the one by the water inlet is a 2 wire sensor.
RetroBlazer
03-28-2012 09:19 PM
zakm0n
01-09-2011 07:31 PM
Malachai
03-27-2010 10:00 PM
mboehler
01-16-2009 07:16 AM
Mulisha
03-24-2008 09:14 PM
Quick Reply: first gen 4.3 temp gauge problem
