fluctuating idle
Old Jan 18, 2007 | 11:42 AM
sorensic42's Avatar
sorensic42 is an unknown quantity at this point
Default fluctuating idle
i have an 89 s 10 blazzer with a 4.3 tbi. the engine idle fluctuates from low to high. at times it will stay at a reg idle, but not for long. when put into gear(auto trans) it wants to stall. to keep it from stalling, you have to pump the accelerator. i have replaced theiac, o2 sensor, and the tps but with no success. the egr valve has been removed and cleaned and all the vacum lines appear to be ok.any sugestions on this matter would be appreciated.
Old Jan 18, 2007 | 12:01 PM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Default RE: fluctuating idle
Try checking the TCC (torque converter clutch) Solenoid
also known as Trans Control Solenoid
I have seen this part do just as you stated your engine is doing many of times.
Good luck
Old Jan 18, 2007 | 12:06 PM
sorensic42's Avatar
I willdo that. thank you for your help
kwoodkayaker
Engine & Internal
14
May 7, 2010 03:05 PM
mdkuni
16
Apr 10, 2008 07:41 AM
Sunshine Coaster
Oct 17, 2007 11:30 AM
ssilk12001
Sep 14, 2006 01:16 AM
dashyman
Aug 29, 2006 01:05 AM
