Fuel Filter Wrench sizes
Old Dec 17, 2010 | 02:54 PM
drummerdude's Avatar
drummerdude is on a distinguished road
Well... the filter wasnt my problem. Still doesnt start right. The filter needed to be changed anyway, but it just doesnt solve my problem. I found that if I try to start it 2-3 times, it usually starts. I'm working on finding a fuel guage, as I'm cheap and dont want to buy one. on the 4.3 v6, where do I find the port to attach to, I had looked under the hood before and couldnt find anything?
Thanks
Old Dec 17, 2010 | 03:53 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Back of the driver's side head there will be a schrader valve on the fuel line closest to the fender, hopefully with a black cap on it (if no cap, get one for it).
Harbor Freight has fuel pressure gauges for under $20, but you can 'rent' one from Advance or Autozone.
EDIT: found a pic with the upper manifold removed. The schrader valve is in the upper right, circled in red.
Old Dec 18, 2010 | 12:54 AM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Default If you are having problems starting it
I would say either you need to replace the fuel regulator which I a $50 orilley part or your ISC is bad and that can cause a no start.
And my fuel filter was a biotch! The fittings are rusted and I had to take the rubber fuel line off to unscrew it, stupid.
Old Dec 18, 2010 | 09:35 AM
abig84's Avatar
Originally Posted by Leeann_Bravada
Really? I had no problems with the flare nut wrenches and PB. Not with open-end. The fuel filter on mine was original, too.
might depend where your located. out in the chicago area ive seen brake lines rot out on 6 year old cars. my 93 s10 someone cut the line when they did the filter and my 90 fullsize i dont even want to touch it cause there is no way its coming off
NorthernCrew454
Feb 15, 2010 11:14 PM
dacop
Jan 16, 2010 06:12 PM
dimmuborgir6nik6
Mar 28, 2009 06:15 PM
Ryanesque
Tires and Wheels
Oct 22, 2008 06:22 AM
95LS
Jun 13, 2008 02:18 PM
