Fuel Line
Old May 13, 2014 | 06:21 PM
AML19's Avatar
AML19 is on a distinguished road
Default Fuel Line
I'm currently trying to replace my fuel line. Any tips?
Old May 13, 2014 | 06:42 PM
Badco's Avatar
Badco is on a distinguished road
Get the tank as empty as possible to reduce the amount of gas you lose
Get a bit more line than you need
Get lots of rags handy
Work in a well ventilated area
And the obligatory don't smoke
This would also get to be a very good opportunity to replace your fuel filter, as well as check the fuel pressure at the pump. I don't know about you, but I'd hate to have the entire thing torn apart, replaced, and then find out later you have a torched pump.
I'm assuming you're replacing them with steel braided line?
Old May 13, 2014 | 06:59 PM
AML19's Avatar
I hadn't figured out what to use yet. I assume that is what you would recommend?
Old May 13, 2014 | 08:32 PM
Badco's Avatar
Ive heard some good things about it. Never used it personally. Hopefully some of the other members can shed some light on it. Maybe look up some youtube videos and reviews of steel braid line. I am almost certain that is what they use on high performance cars, like the kind you would see at the strip.
What is the reason for changing your fuel lines? Do they leak?
Old May 14, 2014 | 06:36 AM
AML19's Avatar
Leak is an understatement. I got into an accident a couple months ago because of a blown break line. I was eight months pregnant at the time so instead of fooling with it, I took it to get fixed. The next day gas was spraying out of the line just before the back tire. So it's just been one thing after the next, and with a new baby in the remix, I just don't know where to start. I appreciate the advice.
Old May 14, 2014 | 11:10 AM
odat's Avatar
when i built my toy PO had used standard fuel hose zip tied to the old frame - when i built i used standard fuel hose on return and vent - high pressure side i used 3/8 steel line tied to the frame with fuel ing. hose for attaching the ends
Old May 14, 2014 | 11:19 AM
newguy's Avatar
Dont know about a 92 but on my 98 I had to get the fuel lines from a dealership. About 80 apiece I believe
Old May 14, 2014 | 11:35 AM
odat's Avatar
yup with mine i couldn't use stock set up - custom frame - I just looked at rock auto for a replacement set - 4wd $86.79 - 4 door $115.79
Old May 14, 2014 | 02:37 PM
AML19's Avatar
I think I have a plan now. I can just use standard line and I don't have to replace the entire line. Since the break line is brand new I don't have to worry about screwing that up. The tank is empty and it is sitting outside with a flat. Guess it's time to get dirty!
bigdaddykane93
Jun 25, 2012 01:24 AM
95jblaze
Aug 27, 2011 03:46 PM
Fossil Rock
Jan 5, 2009 09:16 AM
drefda
Mar 13, 2007 03:45 PM
pilgrim
Engine & Internal
Nov 14, 2006 02:06 PM
