Fuel line access fitting
Old Oct 19, 2012 | 11:27 PM
banjomaniac's Avatar
banjomaniac is on a distinguished road
Default Fuel line access fitting
I have a 94 blazer with the 4.3 vortec. There is some sort of fitting, sort of like a schrader valve (not sure what the right term is) next to the ignition coil. Is there supposed to be a cap over that? It seeps fuel out of the top. I'm guessing that nothing I just mentioned is how things are supposed to be.
I haven't owned this blazer very long and don't much about it so all help is highly appreciated.
Old Oct 20, 2012 | 12:23 AM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
yea thats a fuel pressure test port. you could try tightening it with a valve stem tool for tires. you dont have to have a cap on it although there should be one there. i put in new fuel lines and that same shrader valve your talking about was leaking brand new. i took a valve stem tool and tightened it up a bit and stoped leaking. if tightening it up dont work try taking it out and cleaning it with carb cleaner and spray some inside the hole. take a que tip and go around the inside of it. and put it back in. are you sure its by the coil and not the distributer and brake booster behind the engine closest to the firewall? or are you talking about the air conditioning lines?
Old Oct 20, 2012 | 04:52 PM
Sorry I meant distributer back by the firewall. I'll give all the steps you mentioned a shot. Thanks for all the help.
Old Oct 20, 2012 | 08:42 PM
bam_9_9_9's Avatar
oh my mistake i meant to say valve core removal tool. thats what you need to tighten it up with.
Xavier
Apr 11, 2014 11:49 AM
wisowebs
Dec 26, 2013 06:58 PM
bigjon720
Apr 1, 2011 07:17 PM
NYC86ZC
Dec 12, 2010 08:21 AM
ChevyFamily
Jul 10, 2009 06:41 PM
