fuel pressure problems
Old Dec 3, 2007 | 09:45 PM
michellei's Avatar
michellei is an unknown quantity at this point
Default fuel pressure problems
i am having trouble with the fuel pressure on a 94 chevy blazer,4.3cpi.i need a diagram for the fuel pump, and the fuel pressure regulator. as of now i am only getting 40-43 psi. help
Old Dec 6, 2007 | 12:26 PM
Shabba's Avatar
Shabba is an unknown quantity at this point
Default RE: fuel pressure problems
Do you have an OEM fuel pump or an aftermarket? I had the same problem on my 95. Had to put in a stock one and found a leak in the fitting at the fuel spider. Also replaced the spider with stock. Blazers don't seem to like the aftermarket fuel parts much. Need like 61 lbs to start the vehicle. No other leaks in the system which may allow it to bleed down?
MuddyWater87
Apr 25, 2011 09:57 PM
cardude59
Aug 22, 2010 11:08 PM
multiplicityz
May 23, 2010 02:14 AM
bandidolenny
Aug 12, 2009 11:48 AM
Spartan66
Jul 11, 2008 02:34 PM
