Fuel problems.... help!!
Old Mar 6, 2008 | 07:19 AM
ibew300's Avatar
ibew300 is an unknown quantity at this point
Default Fuel problems.... help!!
I have a 1992 S-10 4.3L vortec. It will start easily and hold steady idle, but as soon as I hit the gas pedal, it dies and won't start again until I pour gas down the throttle body, then will fire right up, burn the gas off and die....after about 3 times doing this procedure and holding the accellerator down slightly it will again hold a steady idle ..... until I hit the gas again.
Recently I've replaced plus, wires, rotor, cap, thermostat, fuel pump, fuel+air filter, cat converter and muffler, and ran sea foam through it.
It's been doing this for quite some time now. sometimes after I let it sit for a couple days, it will fire up and run good and I can drive to work for a couple days, then problem comes back again.
Any suggestions!!?? I sure need to get back to my job!
Awesome site here
Old Mar 6, 2008 | 09:39 PM
94blazer4.3ho's Avatar
94blazer4.3ho is an unknown quantity at this point
Default RE: Fuel problems.... help!!
after the fule pump replacement did you check your fule presure maybe a faulty pump or maybe water in the tank just some suggestions. good luck
95jblaze
Aug 27, 2011 03:46 PM
laidblazer
Nov 11, 2010 03:20 PM
elcoomagnifico
Nov 22, 2009 08:02 PM
Raanerud
May 6, 2009 06:49 AM
upblazer95
Apr 4, 2009 08:27 PM
