Fuel pump ???
Old Sep 29, 2012 | 07:38 PM
pantealeo's Avatar
pantealeo is on a distinguished road
Question Fuel pump ???
When the fuel pump breaks down, does it go all at once,or goes failing over time ?
Old Sep 29, 2012 | 07:45 PM
workshop4ever's Avatar
workshop4ever is an unknown quantity at this point
Either is possible. Typically when it is starting to fail it will begin to make noise. Usually the pump will make some noise, but when failing it will get louder and much more noticeable. If you think it's noisy, best to replace it now....before it does fail altogether. It is also possible for it to just fail altogether one day, though typically unlikely. It is more likely that an unexpected failure would be from a bad relay or electrical connection than a pump just instantly dying.
Don't under ANY circumstances replace it with a airtex/autozone pump. You'll be replacing it again within a few months. Take the time to buy a Delphi pump and you'll be glad you did later on.
Old Sep 29, 2012 | 07:53 PM
pantealeo's Avatar
Thanks for the input,and the tip about the delphi pump,will surely have it on mind...
Old Sep 30, 2012 | 09:14 AM
richphotos's Avatar
You should have only delco or delphi on your mind for the pump, if you have anything else in your mind for brands, remove that thought. Because they SUCK.
Old Oct 6, 2012 | 10:27 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
they tipically either work or dont work.
Old Oct 7, 2012 | 12:35 AM
ohsofly's Avatar
Ive had em just quit, and get noisy. Pressure test is your best bet. Amd x3 on the delco only.
Old Oct 7, 2012 | 08:54 AM
NCSurvival's Avatar
NCSurvival is on a distinguished road
Sure this is a difference of opinion, but Bosch does make a good fuel pump for it. I know, I ran one in a 93 I owned.
Old Oct 7, 2012 | 09:01 AM
richphotos's Avatar
Originally Posted by NCSurvival
Sure this is a difference of onion, but Bosch does make a good fuel pump for it. I know, I ran one in a 93 I owned.
I respect your opinion. But the data does not lie. A simple search will show you that 99% of people have the new pumps fail in a couple weeks or months if its not delphi or delco
Old Oct 8, 2012 | 06:41 AM
NCSurvival's Avatar
I must have been the exception. That Bosch pump took me 3 years and then I had to give the truck up due to frame damage because someone forced me off the road.
Old Oct 8, 2012 | 06:58 AM
red blazer guy's Avatar
red blazer guy is on a distinguished road
my fuel pump died a slow, noisy and painful death...you may as well replace the sending unit while you are at it too
