Fuel Pump Died.
#23
but on what i said last, you should get about 60 while running.
#25
also, when you did the pump the last time, did you change the fuel filter?
#26
I checked it at the schrader valve. When hey on, it shoots to 62. But runningm idling it is about 50 psi, when I stab the throttle, it goes to about 58 psi. Brand new spider and fpr. Brand new fuel filter, all installed approx 300 miles ago or 3 months. Not my daily driver. I noticed it start to miss at idle and the whine of the fuel pump gotten much louder. Not sure how to check the pressure at the filter, I don't have any fittings for that. Ground is excellent as well
#27
sorry to jump in with little help, i have a selfish question, as i will probably be doing a fuel pressure check shortly: does the fuel pump often make such a loud wine? is that normal? healthy? not good? and where does one connect the pressure gauge? just prior to the filter comign from the gas tank?
i have also just changed spider injector, fuel filter, and the issue of mine stalling out has ceased thus far. 500km so far anyways.
BouncingRadical
14
11-27-2015 12:30 AM
Steven Auger
02-06-2013 10:22 PM
kennycraze
09-05-2011 08:26 AM
