Fuel Pump Died.
Old Mar 12, 2013 | 08:51 PM
  #21
mr.vls's Avatar
My pump is for a TBI which only needs around 11 psi.
Old Mar 12, 2013 | 08:54 PM
  #22
richphotos's Avatar
I honestly did not check after I installed the new pump.
Old Mar 12, 2013 | 08:57 PM
  #23
richphotos's Avatar
Originally Posted by jaystoy
What kind of fuel pressure are you getting with the new fuel pump? I just installed a new Delphi pump in my 94 s10 cpi and I am only getting 50 or 51 psi at idle. Is this enough pressure?
but on what i said last, you should get about 60 while running.
Old Mar 13, 2013 | 07:29 AM
  #24
jaystoy's Avatar
jaystoy is on a distinguished road
Damn! All that work to drop the tank again and put in yet another fuel pump!
Old Mar 13, 2013 | 04:17 PM
  #25
richphotos's Avatar
where are you checking the pressure at?
also, when you did the pump the last time, did you change the fuel filter?
Old Mar 13, 2013 | 06:27 PM
  #26
jaystoy's Avatar
I checked it at the schrader valve. When hey on, it shoots to 62. But runningm idling it is about 50 psi, when I stab the throttle, it goes to about 58 psi. Brand new spider and fpr. Brand new fuel filter, all installed approx 300 miles ago or 3 months. Not my daily driver. I noticed it start to miss at idle and the whine of the fuel pump gotten much louder. Not sure how to check the pressure at the filter, I don't have any fittings for that. Ground is excellent as well
Old Mar 13, 2013 | 10:14 PM
  #27
clicheche's Avatar
clicheche is on a distinguished road
sorry to jump in with little help, i have a selfish question, as i will probably be doing a fuel pressure check shortly: does the fuel pump often make such a loud wine? is that normal? healthy? not good? and where does one connect the pressure gauge? just prior to the filter comign from the gas tank?
i have also just changed spider injector, fuel filter, and the issue of mine stalling out has ceased thus far. 500km so far anyways.
BouncingRadical
14
Nov 27, 2015 12:30 AM
Steven Auger
Feb 6, 2013 10:22 PM
kennycraze
Sep 5, 2011 08:26 AM
dbaas
Aug 9, 2011 08:46 AM
Eff10
13
Jul 22, 2011 01:01 AM
