Fuel pump question???
Old Nov 25, 2008 | 09:53 AM
  #21
fourplayinmi's Avatar
fourplayinmi is an unknown quantity at this point
Default RE: Fuel pump question???
okay dumb question but is the cmfi trhe same as the cpi? in the chiltons book I was tryin to look up fuel pressure numbers an the cmfi is callin from 58-64 psi is that what I should be getting at the rail? also what adaptors do I need to test it at the filter? The shop couldnt guarentee that thats gonan fix the problem so I brought it home.. Took the plenum off an everything looks good an new under there so now its leading me back to the fuel pump, I check all the lines for kinks or anything ordinary everything looks good! an it has a new filter. So I called the dealership an a another new pump is on its way will be in tomm am but now they want the Vin number an milege of the vehicle is this normal?
thanks alot for all the help!!!
Old Nov 25, 2008 | 10:22 AM
  #22
The fuel pressure requirements between the CPI motor that is in your truck and the newer SCFI is the same. You need in excess of 52psi for proper opening of the poppet nozzles that are used.
Old Nov 25, 2008 | 10:59 AM
  #23
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Yes, CMFI = CPI
Old Nov 25, 2008 | 02:26 PM
  #24
so it wasnt normal for when I turn the key on it went to 45 an after the pump shut off it dropped to 20ish psi?
Old Nov 25, 2008 | 02:32 PM
  #25
No, not at all normal.
Old Nov 25, 2008 | 02:33 PM
  #26
would that be the pump faulty then? or is there another place that it can lose pressure like that?
Old Nov 25, 2008 | 02:37 PM
  #27
Um, someone else can better answer that, but there are 2 places that could cause leakdown: one is the fuel pressure regulator, the other the fuel pump.
I can't remember what test tells you which is bad, though...
Old Nov 25, 2008 | 03:08 PM
  #28
Run down through the test in the DIY section. Even though I think I wrote it up for the SCFI motors, the components are very similar and the pressures are the same. The diagnostic chart that I posted will point you at the appropriate component at fault.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
