fuel pump troubles
Old Mar 20, 2008 | 09:18 PM
bigt's Avatar
bigt is an unknown quantity at this point
Default fuel pump troubles
I have a 1989 s10 4 x 4. Was running fine and now won't start. Checked for spark had plenty. Pulled the gas line going into tbi and no fuel flow. Hoped and prayed for a clogged fuel filter. Replaced it and still no gas flow. If I pour some gas into tbi the old gal will fire right off till it burns the gas out then dies. I assume it has a electric fuel pump which with my luck will be in the gas tank that I just filled up. How can you tell if it is bad? Is there some kind of relay that might be bad? Does the fuel pump start pumping when the key is turned on? Any help will be greatly appreciated! Thanks
Old Mar 20, 2008 | 09:31 PM
Default RE: fuel pump troubles
You should have a fuel pump fuse and a fuel pump relay.
Old Mar 21, 2008 | 06:18 AM
bigt's Avatar
Kyle, Where would the fuel pump fuse and relay be located at? Thanks, Tim
Old Mar 21, 2008 | 10:31 AM
Campesino's Avatar
Campesino is an unknown quantity at this point
Whats the size of the engine?
Old Mar 21, 2008 | 10:33 AM
bigt's Avatar
It is a 4.3 Thanks
Old Mar 21, 2008 | 06:56 PM
The ECM B fuse feeds +12V to the Fuel Pump relay for the supply to the fuel pump.
Here is the electrical schematic and the location of the fuel pump relay:
Old Mar 21, 2008 | 09:54 PM
bigt's Avatar
Kyle, Thanks for the info!! Happy Easter, Tim
Old Mar 22, 2008 | 07:53 AM
No problem!!
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
