gas pedal sticks?
Old Nov 3, 2010 | 09:59 PM
Maestro's Avatar
Maestro is on a distinguished road
Default gas pedal sticks?
got a gas pedal issue i was hoping someone would know what to do...
i have an 88 blazer 4x4 2.8....gas pedal is fine when its not running..but when it starts up...the gas pedal is sticky ((ie...doesnt want to go down))
any info on this is much appreciated...thanks in advanced
-Maestro
Old Nov 3, 2010 | 11:32 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Think you have something misrouted or just worn out. Take a hard look at how the cable is routed.
Old Nov 4, 2010 | 10:25 AM
Maestro's Avatar
i think ive figured out the issue...
seems to be a butterfly valve sticking in the throttlebody...no idea if it can be fixed or just have to replace...any ideas?
Old Nov 4, 2010 | 07:24 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
If there is any soot or buildup it needs to be cleaned out of there. Does it idle properly? I would make sure there is nothing obstructing the cable and see how hard it is to turn the throttle by hand.
Old Nov 21, 2010 | 09:46 AM
bouts5991's Avatar
bouts5991 is on a distinguished road
befor i owned my own blazer, i drove my moms around alot, roasted it and what not. but she always complained that the gas pedal sticked only when she first wanted to take off. if she were to drive down the highway itd be fine, cause her foot would have the throttle open a little bit, but as soon as she let off, the butterfly in the throttle body would close up for idle and stick... some brake cleaner and a screw driver fixed that issue no problem. it ended up not being anything in the throttle body, but there was undercoat sprayed up from under neith, and was basicly holding the pin back from not opening smoothly
Trying
Jun 10, 2013 04:47 PM
ryito1122334455
Oct 8, 2011 03:08 AM
NYCJUDGE
Aug 28, 2011 04:35 PM
Rickc46
Dec 31, 2009 10:22 AM
sketch12
Jan 12, 2006 07:26 PM
