Gauge Cluster Help Please!!!
Old Jun 27, 2011 | 11:37 PM
tred2587's Avatar
tred2587 is an unknown quantity at this point
Default Gauge Cluster Help Please!!!
I am trying to install a gauge cluster that runs an electrical speedo and my 1986 blazer needs an actual odometer cable for the speedo to function any way to modify to bypass this situation. Isnt there some type of converter?
Old Jun 28, 2011 | 01:58 AM
chris015's Avatar
YouTube - ‪Chevy S10 - Cable to Electric Cluster Tutorial‬‏
there ya go! Everything you need to know. Just go backwards with it.
Old Jun 28, 2011 | 02:25 PM
tred2587's Avatar
thats an interesting tutorial i like it but doesnt help in my situtation lol. Let me explain. I am changing clusters on my 1987 s10 blazer to a cluster that comes out of an 1988 chevrolet 1500 pickup with at 4.3ltr v6 and an electrical 700r4. I included a picture of the gauge cluster. Is there any other way getting around this issue
Old Jun 28, 2011 | 05:55 PM
If your truck originally came with a mechanical speedometer drive and you are swapping in an electronic speedo, you can get a converter. I think that the early GM VSS output 16 pulses per revolution. This would be modified by the current gear in the transmission output (or transfer case output if 4wd). Unless you get a DRAC (digital ratio actuator control), you will have to make certain that your current gear in the transmission is proper for your axle ratio & tire size.
Check out the JagsThatRun website (<--CLICK) for some more information.
Old Jun 28, 2011 | 06:01 PM
chris015's Avatar
^^ yep. and that cluster you have is a "moon cluster". I had one in my 1500 truck before i scrapped it.
blazerguy09
Jan 7, 2015 03:26 PM
916slapin
Nov 4, 2011 03:32 AM
wcook369
Nov 27, 2010 11:42 AM
3kidblazer
Feb 1, 2009 11:22 PM
offroadin974wd
Jan 22, 2007 10:37 PM
