getting these codes 22 32 34 82
Old Aug 27, 2009 | 08:29 PM
shredyou's Avatar
shredyou is on a distinguished road
Default getting these codes 22 32 34 82
i have a 93 s10 cpi i did the paper clip trick and got these codes 22 32 34 82. my truck runs alright but it doesnt have the power it used to. i usually dont have the mil on but sometimes when i idle for a while it will come on, or if i put it in reverse and step on the gas it gets really jerky like the fuel surges and then cuts out then surges and cuts out, some times it stalls in reverse. a while ago i took the egr apart and cleaned it up but it didnt help. any ideas or thought would be appriciated.
Old Aug 27, 2009 | 09:13 PM
jamesbalzer's Avatar
jamesbalzer is an unknown quantity at this point
Try cleaning the MAF Sensor.
Old Aug 27, 2009 | 09:21 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
93 doesn't have a MAF; it has a MAP.
First code is always the most important. Fix that, clear codes and run a test drive. In your case, it's TPS voltage was under 0.2 volts for 4 seconds when the ignition was on. Test the TPS and replace if it is under/over spec.
Old Aug 27, 2009 | 10:47 PM
shredyou's Avatar
Default thanks
i will check the 3 wires with a multimeter tomorrow and get back to you.
Old Sep 2, 2009 | 11:12 PM
shredyou's Avatar
Default adjusted tps sensor
i adjusted the tps and i have these voltages 0.0 ground 0.44 tps feed closed and 4.8 open 5.12 constant. i still get the same codes 22 32 34 82 and the car still revs and cuts revs and cuts almost to the point of stalling when i give it wide open throttle in reverse gear. but this only happens in reverse.
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
Blazin_Jason
Suspension Tech
Apr 15, 2007 07:43 PM
