Has anyone ever seen a fuel pump harness melt?
Old Nov 15, 2008 | 08:44 AM
DC_X's Avatar
DC_X is an unknown quantity at this point
Default Has anyone ever seen a fuel pump harness melt?
This started out simple enough, not enough fuel pressure. Decided to replace the pump, filter, and check for leaks.
Larger image here.
Drop the tank, pull the unit, and low and behold, it runs, but I have no idea how. Any suggestions on what could have caused this? Honestly, it looks like fire damage, IN MY FUEL TANK, but I doubt it. Could heat from a failing fuel pump do this, and how on earth do I replace that lone connector without dropping another tank at the salvage yard?
[Edit]
It would appear reading the directions for the new pump was the key. The replacement unit I purchased from Carter actually includes the part to completely replace the harness at all points, and even mentions the possibility of the harness melting.
Old Nov 15, 2008 | 09:46 AM
mysons95's Avatar
mysons95 is an unknown quantity at this point
Default RE: Has anyone ever seen a fuel pump harness melt?
Any fried squirrel teeth stuck in that mess? lol
Poor little squirrel. [sm=violin.gif]
Old Nov 15, 2008 | 10:30 AM
If the pump shorts out, it can cause enough heat to melt the connection. A fuel tank does not have enough oxygen in it to support free burning of the fuel.
Old Nov 15, 2008 | 03:10 PM
Duntov's Avatar
Banned
Duntov is an unknown quantity at this point
Did you ever wonder whythe fuel pump manufacturers always recomend replacing the wiring harness when you replace a fuel pump? Now you know.
I heard a unsubstantiated claim that if you run the fuel tank extremely low many timesbefore eachfill up, the fuel pump or fuel pump harnessmay overheat and "burn" out.Maybe there is soneting to that claim.
Old Nov 19, 2008 | 05:53 AM
rx7_guy's Avatar
rx7_guy is an unknown quantity at this point
Bad motors (pumps) will have a higher amp draw...the wire can't not support this draw and gets very hot. Also...not having a load (fuel) can cause this problem as well.
ZaBlazer99
Jan 19, 2013 08:20 AM
rexmburns
Oct 8, 2012 02:08 PM
ihatefordz
50
May 12, 2012 05:06 PM
willjones
Mar 24, 2010 11:37 PM
Lomm3r_93
Feb 27, 2010 10:44 PM
