headlight problems
Old Feb 28, 2007 | 07:08 PM
93chevyblazer's Avatar
93chevyblazer is an unknown quantity at this point
Default headlight problems
[8D]ok i have a 93 s10 blazer 4x4 with light problems the drivers light is always a daytime runner even when i put the high beam and normal light
Old Feb 28, 2007 | 07:36 PM
drperry's Avatar
Default RE: headlight problems
Try wiggling the plug on the back of the light, or checking the headlight fuses.
Old Mar 5, 2007 | 04:12 PM
the light is always dim and i changed the harness and the fuses checked the wires and the grounds and still nothing
Old Mar 5, 2007 | 06:55 PM
drperry's Avatar
Did you check both fuses? I think there's two for that year of truck...
Did you try another light on the same plug?
Check all your fuses, I can't remember for sure, but I think there's one that when it's burnt, it causes this issue... If it's not the headlight fuses, lol.
Old Mar 6, 2007 | 12:22 AM
ok so i took the whole dash out and found that the truck had an alarm and auto start so carefully found every wire that was hooked to the harness cut them and going to try this now but if not im changin the interior anyways so i will take old harness from my junk 93 blazer to see if that does anything
FlatTopFoley
Sep 1, 2011 01:57 PM
davep
Jan 14, 2010 11:31 AM
cueball
Aug 29, 2009 10:37 AM
JonSDSU
Jan 22, 2008 03:31 AM
blazerxtreme1
Jul 29, 2006 04:45 AM
