help
Old Aug 20, 2011 | 05:47 AM
cass's Avatar
cass is an unknown quantity at this point
Default help
my 94 blazer idles smooth but when tack hits 2 it dies
Old Aug 21, 2011 | 11:18 PM
just plain lucky's Avatar
just plain lucky is on a distinguished road
idles so so but go for the gas and it cuts out???
Old Aug 21, 2011 | 11:19 PM
xgiovannix12's Avatar
ID start by checking the fuel pressure sounds like you got fuel problems
Old Aug 21, 2011 | 11:57 PM
seancipper's Avatar
seancipper is on a distinguished road
idle speed sensor??????
Old Aug 22, 2011 | 01:29 PM
cass's Avatar
thanks i will try that
Old Aug 27, 2011 | 02:39 PM
Since it falls flat at higher RPMs, I would suspect a clogged catalytic converter. You cant test this by disconnecting & removing the upstream O2 sensor (located between the 'y' in the y-pipe & the catalytic converter). Take it for a spin. It will be loud, but if the cat is clogged, it should run better.
