HELP!! 98 S10Blazer has no voltage
Old Aug 29, 2009 | 12:01 PM
Ricky0221's Avatar
Ricky0221 is on a distinguished road
Default HELP!! 98 S10Blazer has no voltage
Blazer has been running fine until this am. Went out to start it and nothing, dead, hooked it up to jump it off and it would start and then cut off as soon as the jumper cables were removed. I went and bought a new battery and the same thing happened, dead, jump it off it starts right up runs for a few seconds and dies as soon as cables are removed. It is getting no voltage at all, with new battery power door locks or windows will not work. Blazer has a new fuel pump, so I don't think this is the problem, can here the fuel pump click on when it starts. The security light will flash for a sec or two when it is running ( with the cables attached) then it goes off. Any suggestions??
Old Aug 29, 2009 | 12:05 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
check the cable from the alt to the battery or just run a new one
Old Aug 30, 2009 | 09:14 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Did you have the battery tested before you replaced it? Pull the alt and have it tested, as well. It's only a few bolts.
Old Aug 30, 2009 | 10:34 AM
two1nine's Avatar
two1nine is on a distinguished road
check the cables as stated before it may be that alt but its juicing that battery to where the locks dont work im not so sure
Gil_87
Aug 14, 2011 11:26 PM
WantBlazerToRun2000
Apr 21, 2011 06:29 PM
2001Blue
Dec 31, 2010 12:16 PM
driftingrz
Feb 9, 2010 11:48 AM
danyboy
17
Dec 23, 2009 08:02 AM
