help!not getting spark!!
Old Aug 14, 2010 | 05:18 PM
pizza123415's Avatar
pizza123415 is on a distinguished road
Unhappy help!not getting spark!!
im not getting spark even after i put a new cap and rotor. today i tried a new coil and still nothing. Does the coil need to be grounded maybe???
Old Aug 14, 2010 | 05:21 PM
Do you get spark out of the coil when testing directly from the coil?
Old Aug 14, 2010 | 05:28 PM
yea i tested if i was getting spark form the coil to the distributor and nothing but the small wires that hook up to the coil are hot
Old Aug 14, 2010 | 06:32 PM
If it is getting spark from the coil, then the problem lies in the distributor. Are you sure that the timing is set properly?
Old Aug 14, 2010 | 08:45 PM
no spark from the new coil.and im sure my timing is set properly.perhaps its the distributor
Old Aug 15, 2010 | 01:39 PM
So which is it...? Is it getting spark from the coil or not? If not, then your problem exists before the distributor.
Old Aug 15, 2010 | 04:12 PM
NO spark from the new coil.my second guess would be the distributor module unless the coil needs to be grounded(lost the bolts to bolt it back on the bracket)
Old Aug 15, 2010 | 05:08 PM
It sounds like your ESC (electronic spark control) module isn't working properly.
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
LO3671
Apr 4, 2010 01:26 AM
