High Idle
Check for a vacuum leak. My sons 1995 had a bad vacuum line from the engine to the vacuum reservoir and it affected the heater/ac controls (only blew out of the defrost vent) and made the vehicle idle fast. Replaced the vacuum line and that restored function of the heater/ac controls and ended the fast idle.
I was told that you can use spray carb cleaner and spray around vacuum lines while vehicle is running (be careful... I would have fire extinguisher handy!!). If there is a vacuum leak, the engine will idle even faster when the carb cleaner is sucked into the intake.
mcdevin1973
Oct 5, 2014 02:52 PM
midnightryder
Dec 29, 2009 02:43 PM
