hood release cable
Old Oct 11, 2010 | 09:15 PM
4x4blaze's Avatar
4x4blaze is on a distinguished road
Default hood release cable
mine is hard to open and i notice where it attaches to the latch on the hood its coming apart. like fraying a little. how hard is it to replace.
Old Oct 11, 2010 | 10:52 PM
rob44_90's Avatar
rob44_90 is on a distinguished road
Mine was doing the same thing to me about two years ago. I sprayed a lot of WD-40 directly on the latch and into the cable, and it has worked fine ever since.
Old Oct 12, 2010 | 10:15 AM
mr.vls's Avatar
Replacing is fairly easy. I replaced mine with one from a junkyard last year. There are a few clips in the engine compartment and feed it through the firewall and mount under the dash.
Old Mar 9, 2011 | 12:08 AM
just plain lucky's Avatar
just plain lucky is on a distinguished road
To replace just find one at pep boys or auto zone don't remove cable cover and just pull it out the cable that is the replacement one will just slip right in then adjust inside below the dash, no big deal. The other way would be to go to the junk yard and find one cable and cover and replace the whole darn thing. Eighther way its not too hard. Good luck. Just Plain lucky.
Old Mar 9, 2011 | 12:09 AM
Default Two ways
Old Mar 9, 2011 | 07:20 AM
mr.vls's Avatar
I am not sure how the cable from Pep Boys ore Auotzone is made but the OEM handle is bonded to the cable and the engine side has a lug that is crimped on the end from the factory. There is no way to pull a cable through the tube. You need a complete assembly either new or used. When my pull handle broke I found a replacement in the junkyard. It is easy to remove and install.
sprbld417
Apr 25, 2011 07:28 PM
DAVE SR
Nov 7, 2010 03:10 PM
tmitbyh
Oct 13, 2009 08:01 AM
blazer4x4
Sep 12, 2007 11:59 AM
Hanr3
Jan 22, 2007 02:30 AM
