How to check Fuel Pump?
Old Dec 14, 2007 | 04:49 PM
ptcoins's Avatar
ptcoins is an unknown quantity at this point
Default How to check Fuel Pump?
Is there any way to check my fuel pump before I replace it?
I ran my 1992 S-10 blazer (4.3L vortec) out of gas and it hasn't run right since. It will start, but will die easily when pressing the accelerator. It will usually idle fine for long periods of time, although it has died a few times.
If my pump does need replacing, is it easy enough for the average person to do at home?
Old Dec 14, 2007 | 05:26 PM
Default RE: How to check Fuel Pump?
Do you have a TBI motor (large round air cleaner on top of the engine)?
Old Dec 14, 2007 | 07:56 PM
ptcoins's Avatar
4.3L vortec
Old Dec 14, 2007 | 08:42 PM
So do you have the large round air cleaner or does it have the the black plastic trim cover with orange 'Vortec' embosed on it? 4.3L Vortec describes every 4.3L motor produced as vortec was the design of the cylinder heads since the inception of this particular 4.3L v6 engine from GM.
But because you say this, I am assuming you have the CPI motor. In which case, there is a fuel pressure test port on the back of the intake manifold towards the driver's side. To properly determine the condition of the fuel pump, you should run a pressure test with a fuel pressure gauge connected to the test port.
Old Dec 22, 2007 | 02:04 PM
No response? From your other threads, I found that you have a 'W' code truck which means CPI. Thanks for providing that information... As I stated, you must check the fuel pressure with a fuel pressure gauge connected to the fuel pressure test port located on the rear of the intake plenum towards the driver's side.
*Moving to 1st Gen Tech*
Old Dec 23, 2007 | 03:05 PM
Brandon31386's Avatar
Brandon31386 is an unknown quantity at this point
jumper the relay and listen for the pump. Relay is located on the firewall drivers side. Put a jumper from the orange wire to the gray. Orange is constant power to the relay, gray goes to the fuel pump. if you dont hear it, it doesnt work. if you do hear it, chances are your relay is bad.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
