How do I get my wind shield wipers off?
How do I get my wind shield wipers off of my 1994 blazer? I don't see any where to get them off and I would like to take them off to sand them and repaint them.
Near the base on the arm you will see a small hole. You need to get a finishing nail or pop rivet that will fit in that hole. Lift the arm enough that the nail/rivet goes in and comes out the bottom. Lower the arm and it will hold the nail/rivet but you can then work the arm off the shaft.
Wiper Blades
Do you have the hook type or the pin type? I have the pin type and put a flat head screw driver between the blade and the arm and twist to pop it off. The hook or J-type should just slide off. Push towards the inside and they will come off.
beeneeb
02-12-2007 06:44 PM
