loud wind howl
Old Sep 13, 2007 | 07:40 PM
jaiburnam's Avatar
jaiburnam is an unknown quantity at this point
Default loud wind howl
can any 1 here gimme sum tipz bout a loud wind noise comin in from the passager side door i just wonderin how i can get rid of it cuz it gettin kinda loud. it mostly comes in at the top of the door right at tha arch if any 1's got ne info bout this please help
oh and by the way this web site totally rocks ever since i found this place and put ta use some of the tips and how to's my blazer is runnin 110% better then it was tha day i bought it thanks to all for ur knowledge and tipz
Old Sep 13, 2007 | 08:22 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
Default RE: loud wind howl
I would check your weather stripping...some times it can come un glued..or it might be time to replace it...otherwise it might be that your window isn't sitting flush with the window frame..what about your rain shields? do you have those? one edge might be loose
Old Sep 13, 2007 | 09:00 PM
hillbillyinOhio's Avatar
also make sure that your door isnt sagging. like check your bushings and hinges between the door and the truck
Old Sep 14, 2007 | 06:06 AM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
Take a sheet of paper and put it between the window rubber and the door frame and close the door , if you can move the sheet of paper freely you have too much of a space between the door and the door opening and need to adjust it ...
To adjust it you will have to put your knee on the door and pull on the door post where the paper is slipping until it gets tight ..
This is kinda hard to explain but a body shop could do it in 5 minutes ...
Zed
Old Sep 14, 2007 | 11:56 AM
Dabber's Avatar
Dabber is an unknown quantity at this point
HA HA Seen that one on trucks too!! I did it soon as I seen it
Old Sep 15, 2007 | 07:11 PM
jaiburnam's Avatar
thank you much peeps i will put those tips ta work
Nuikala
Nov 1, 2012 11:05 AM
vdubb16
Jan 11, 2010 11:26 PM
OILCOUNTRY
Oct 10, 2009 07:57 PM
black19
Mar 17, 2007 09:15 PM
HCCAFan
Feb 4, 2006 03:37 PM
