How Do I KNow It's Just The FPR?
Old May 23, 2007 | 03:56 PM
Daytripper540's Avatar
Daytripper540 is an unknown quantity at this point
Default How Do I KNow It's Just The FPR?
Our 93 Jimmy has a major problem. It sounds like it has a cam when you crank it up, it burns gas like crazy, there is a strong gas smell on the dipstick.... Sources have said that that is the FPR. But how do I know that it is only the Fuel Pressure Regulator and not the entire spider unit? Do I need to take off the entire upper intake manifold first just to check?
Old May 23, 2007 | 04:25 PM
Default RE: How Do I KNow It's Just The FPR?
You can pull off the manifold tuning valve (under the plastic Vortec cover) and have a look down inside, but you cannot really see the other components that are inside the intake. Your best bet would be to remove the upper plenum and pressurize the system. Look for leaks.
bassson
Dec 3, 2013 11:51 PM
livlifes2short
Mar 13, 2009 11:26 PM
rustyd
Sep 17, 2007 09:36 PM
rustyd
Sep 17, 2007 09:28 PM
swearingsailor6
Dec 29, 2006 06:42 PM
