how to fix ciggarette lighter
Old Dec 19, 2006 | 04:24 PM
skitzobmxr's Avatar
skitzobmxr is an unknown quantity at this point
Default how to fix ciggarette lighter
hey, do u guys kno how to fix a broken cigarette lighter, i got this Mio GPS the other day and it connects to the ciggarette lighter for power.....mine broke so unless i get it fixed i have a 400$ paper weight with a touch screen
Old Dec 19, 2006 | 05:41 PM
hillbillyinOhio's Avatar
Default RE: how to fix ciggarette lighter
is it broke or the fuse blown???
Old Dec 19, 2006 | 06:09 PM
skitzobmxr's Avatar
i have no idea it just doesnt work
Old Dec 19, 2006 | 06:33 PM
i would check fuses first. get out your owners manual and it will tell you exactly which one is the cig lighter.
Old Dec 19, 2006 | 06:38 PM
skitzobmxr's Avatar
aright thx
*Combining posts
ill get back to u on that
skitzobmxr's Avatar
Old Dec 19, 2006 | 06:46 PM
Chevy Lover's Avatar
It should be the ctsy fuse....usually
A common fault is that the lighter element gets ruined by a build-up of crap and then when it gets pushed into the lighter housing it shorts out and blows the fuse.
Old Dec 19, 2006 | 08:07 PM
skitzobmxr's Avatar
ya...i looked in my manual for the right fuse...i have no idea wut one it is..i couldnt find anything that said cigarette lighter so ill just have my friend lok at it but thx for the help
Old Dec 21, 2006 | 01:47 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
look for the fuse that says INST (instrament) or INT sometimes they are linked with the Radio fuse.
Forgot have to remove ashtray first then do below
To replace the ELEMENT you have to remove the bracket (two screws some have bolts) pull out mount, remove ground and hot wire from lighter, With no power to it its safe to input thumb to hold element from moving use pair of plyers to turn the cheap case retainerfrom behind it like a twist cap. Unscrew this all the way off, pull out element. Take your $5 avg cost replacement and remove that rear retainer, reverse removal to install.
r_marczak_83
17
Mar 9, 2013 10:33 AM
thanser
Sep 3, 2007 08:31 AM
EuroGoldLS
Apr 13, 2007 03:36 PM
Dodge Guy
Oct 25, 2006 08:48 AM
BlaZeR FXB1581
Oct 23, 2005 05:49 PM
