How to get passenger door open
Old Nov 2, 2009 | 10:14 AM
treysanatomy's Avatar
treysanatomy is on a distinguished road
Default How to get passenger door open
I finally thanx to you folks got my fuel pump fixed. Now my passenger door won't open from inside or out. I can see the rod on the exterior handle has popped off but why will it no open from inside? How do I get my door panel off with door closed? I can get it apart enough to see the handle and lock rods. Not sure what to do from here. Is there schematic somewhere of the how the rods are connected or where I can open it from. I have a Haynaes manual and it show nothing. Please advise.. As always thanx
Old Nov 2, 2009 | 02:52 PM
That is going to be difficult without breaking the door panel... If you can find another one for cheap, just break your current one loose and then get in there to get at the rods.
I am reminded of how I have popped doors at crashes... I have a little utility bar that has a can opener style end on it. I can open a door in only a few minutes time with that tool. It has saved time over getting out the air hammer with sheetmetal bit or getting the jaws out. Of course, you would need a new door after I'm done!..
Old Nov 2, 2009 | 06:12 PM
abig84's Avatar
You can usually start taking off as maÑy door panel screws as you can and try to pull the door panel back and get your hand in there to grab one of those rods. You risk damaging the door panel though
Old Nov 3, 2009 | 02:00 PM
OK I was able to get the door panel completely off. the rods are connected to the inside door handle and door lock. I can only see and feel so much, I was wondering if I were to take a Dremel tool and cut out a piece of the panel to see what I am doing? I did this to the driver door to replace the lock cylinder, or does someone have a better idea?
MikeTastic
Aug 8, 2012 04:41 PM
chris015
Feb 14, 2012 10:20 AM
low1
Dec 7, 2011 08:47 PM
wlorton
Sep 27, 2010 05:49 PM
HiredDriver
Sep 23, 2010 10:00 PM
