i need help
my 4hi is not working recently replaced the push button switch and the acuatar switch on front axel, 4hi worked for awhile then stopped workin when i tried it out a couple times after testing it, could i need a new encoder motor?
I have disconnected the battery before in winter when it wasn't working. got to work. but after winter it stopped workin on me. though 4 low works and i can switch out of 4hi into 2 when 4hi is not engaging.
is the vacuum collector next to the acuator switch on front axel? my s10 blazer is a 92 if that helps out too, and i checked the acuator under the battery the vacuum seem to be workin and there are no leaks i believe.
maximashift
Nov 17, 2009 09:36 AM
blazin4eva
Jan 27, 2005 02:02 PM
