I say U joints--what say you?
Old Dec 13, 2006 | 06:43 PM
ken erestu's Avatar
ken erestu is an unknown quantity at this point
Default I say U joints--what say you?
I have noticed that when I put my Blazer in reverse, there is a slight clunking noise just as it engages. It also happens as I put it in drive or when I am coasting and 'goose it' (enough with the animal references) a bit.
In my limited knowledge, I believe it is a UJOINT issue, hopefully not anything else.
Question: How do I check to see if the ujoints need to be replaced?
Thanks.
Old Dec 13, 2006 | 07:35 PM
Chevy Lover's Avatar
Default RE: I say U joints--what say you?
It could be a u-joint.
I would put the rear axle on jack stands, put the transmission in "N", then grab the diveshaft and the differential yolk and twist back and forth to see if there is movement in the u-joint. There should not be.
Use this method for all the u-joints. The only other way is to remove the driveshaft, then remove (carefully) the u-joint cups and inspect the needle bearings and the internal surfaces of the u-joint and cap for wear.
01blaze2door
Headers, Intake, & Exhaust
Jan 2, 2011 10:20 AM
Shalom
Jul 21, 2010 11:31 PM
JPate
Dec 29, 2009 06:38 AM
mysons95
Oct 31, 2008 05:49 AM
MIKER
Oct 29, 2006 01:19 AM
