ideling and starting issues
Old Jun 7, 2009 | 01:03 PM
Eman5pt0's Avatar
Eman5pt0 is an unknown quantity at this point
Default ideling and starting issues
ok well this is an on going problem i have had, when the truck runs for a while and im sitting in traffic or at a long light it will start to idel like ****, until i start driving than it smooths out. along with that problem its been struggling to start, it will turn over a longer than normal eventually it will start. the plugs and wires have recently been changed, and maybe a year ago the whole fuel system was replaced, tank, pump lines injector. At this point im thinking it has to be fuel
any suggestions ?
thanks
Eric
Old Jun 7, 2009 | 04:04 PM
What is it you are driving?
Old Jun 7, 2009 | 04:40 PM
Eman5pt0's Avatar
yeah that might help lol
a 94 s10 blazer
someone said the EGR might be hung up and to remove it and spray it down ..
Old Jun 8, 2009 | 01:21 PM
Eman5pt0's Avatar
anyone have any pics or diagrams where the EGR is located .. ? hopefully ill get it done tonight
Old Jun 8, 2009 | 04:12 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Front of the motor, below the throttle body (where the intake hose attaches). Looks kinda like a soda can.
You'll need at least 9" of extensions and a 10 mm socket (and stick a little piece of paper towel in it so the bolt sticks better) - for the driver's side bolt. For the passenger-side bolt, you'll need a 10 mm wrench; a ratcheting wrench makes it easier.
You'll also need a replacement gasket. Get the one from the HELP! section - it's screened.
SlickBlazer
38
Oct 3, 2011 02:20 PM
necropenetrator
Dec 27, 2008 05:58 PM
Sprocket
Mar 20, 2008 09:39 PM
kpiper
Dec 15, 2007 06:28 PM
dragonsdeath
Oct 7, 2006 01:08 AM
