idleing rough lack of power
Old Nov 14, 2008 | 07:35 PM
juan8w1's Avatar
juan8w1 is an unknown quantity at this point
Default idleing rough lack of power
ok i replaced spyder and fixed all leaks. but i `am still running rough i even got an egr valve and assumed it would fix the idle prolem but its still runing like its missing or something do i need to run it since a lot of gas got into the cylinders or is there somthing else i am missing oh yes i did a full tune up aswell and i changed the oil ran vacume check and there are no leaks present this is a 94 lazer with the vortec engine any adviewould be greatl appreciated
Old Nov 16, 2008 | 05:36 PM
Default RE: idleing rough lack of power
While you had the intake off, did you clean the throttle body and the IAC (idle air control) valve? A sticking/dirty throttle body or IAC valve could cause an idle problem.
a68cudas
Nov 11, 2009 06:42 PM
juan8w1
Nov 14, 2008 07:35 PM
xekushion
Aug 18, 2008 06:21 PM
Easy 8
Jul 12, 2008 09:46 PM
blazergirl15
Jun 6, 2005 02:02 AM
